Originally Posted by Soaringcook
I do have servicemaxx and nexiq. How can i use it to command the output put for the modulator/relay? And do i plug a light ti the modulator or relay for testing?
It depends on how the modulator is wired or controlled. Some are by ecm, some are by a switch on the throttle pedal. We went through this a year or so ago with simplicity and his bus. IIRC, the modulator didn't effect the tcc working or not, just what rpm it engaged at (lower then normal)
Search the forum for the thread(s) and read through them.
In the shop we always tested them during the annual. With koeo, we'd push the accelerator pedal to the floor and someone underneath would check plunger movement. No plunger movement meant troubleshooting was done to fix the problem.
Search cadillackid's posts too. IIRC again, he did some testing and found the ecm control of the modulator was erratic, and the engine had to be running, which lead me to believe our buses had the "fix" of a switch on the pedal assembly.
