Originally Posted by marceloasherq
I’ve gone to two autoparts stores and they are totally confused, but certain they don’t carry it. Any ideas? In a pinch to say the least. Maybe it’s more than just the relay?
Hey, do us old folks who are experiencing the beginning stages of "CRAFT", fill out your user profile to include your type of bus, engine and tranny model.
That will help us all remember what you got when we are trying to help out.
That being said, that relay is a very common single pole. double throw relay.
In you picture I can see another relay behind the one in your hand. It should be the same as the one in your hand, verify and then swap it out, turn the key without cranking the first time, see if all your dash/warn lights come on. If they do, try starting the bus.
But before you do all that, check your ECU fuse in the batt box just to make sure it did not pop.
Also, relays should NOT just POP OFF. Secure that relay with a screw or a ty-wrap and make sure the cable connector is not loose and can wiggle itself free.
While your at it, check all the relays for the same, make sure they are secure and the wiring connectors are not loose.
