Navistar 7.3L cruise control, overheating
I just got my first bus, also my first diesel of any sort. Mostly I've had passenger cars and motorcycles in the past.
It's a 1999 Thomas mid-bus with Navistar 7.3L.
189k miles. I think it said like 9500 hours.
Drove it back from Cleveland to Detroit with gas pedal pegged, 59 mph, 2700 rpms. 85 degrees outside or so. It did fine for maybe 30 miles, then overheated. Coolant spilled from the overflow tank. I freaked out. But got back on the road and the next time it overheated, I backed off to 55 (2600 rpm). Later I had to back off to 50 (2500 rpm). I was able to go faster here and there as the sun got a little lower in the sky.
Is this normal? If not, any suggestions?
I'd also like to try and get cruise working, and maybe also remove any speed limiters, and apply any efficiency hacks if any exist. And then there's the air leak in the air dryer... (I just learned that an air dryer is a thing, ha)
Thanks for any help!
