No crank issue, advice please.
I have a 2011 international IC CE Maxxforce 7 with 75,000 miles on it.
I started it up fine 10ish days ago but when driving I noticed resistance shifting from park, reverse, and drive when exiting the driveway. I pulled back into the driveway to investigate, and after turning it off it wouldn't crank.
Currently check engine light is one when power is on, and there is no cranks when the key is turned, just a click from the circuit box(driver side left).
Battery voltage seems good. I'm assuming it's a starter issue, but am unsure why I had trouble shifting. I'll take any advice on solutions. Thanks!!!
