Originally Posted by ewo1
So after doing an inframe in my second bus, 2006 Amtran, I found a dang oil leak right at the oil cooler/ filter housing.
Looks like a easy job to do, removal and re-install. Thank goodness I found it before I left to Texas with the bus!
I also found a safety recall sheet that identifies dt466 engines manufactured in 2006-2007.
The recall sheet talks about a cracked housing. Makes me wonder if this is what caused it to get milkshake oil in the first place!
The safety recall sheets walks you thru the process for getting it done. Looks easy to do !
I've actually been thinking about making an adapter plate that bolts on instead of the cooler that would let you run oil lines to a fan powered auxiliary cooler. I was thinking it would reduce the risk of oil and coolant mixing during failure and also reduce some of the heat being put into the engine coolant.
Do you think that would be something worth while or pointless?
