Old 01-31-2022, 04:14 AM   #1
Chassis: Thomas Vista International 3600
Rated Cap: Mid Bus
oil leak at cardan crank shaft
Good day,
my Skoolie international 3600 from 1998 with T444E is leaking oil at the cardan crank shaft (I hope this is the right wording) see attached picture
Im looking for the right spareparts for replacement. Does someone knows the name of the spareparts or knows the correct part number for ordering and shipment to Germany?
I'm native german speaking and do not know the correct english translation
Thank you
Wolfgang
Mcloud is offline   Reply With Quote
Old 01-31-2022, 08:16 AM   #2
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
The picture shows where the driveshaft goes to the differential. If that is the seal you are talking about it is called a pinion seal.
The seal will have a number on it, or should be able to look it up. Do you have International truck dealers in Germany?
There should also be some sort of tag on the axel housing with information.
Old 01-31-2022, 11:44 AM   #3
Year: 1954
Coachwork: wayne
Engine: cummins 12 valve
need a little more information
There should be a identification tag. One tag should be on the differential. That is the part you have in the picture. The second tag of information should be on the rear axle housing. The driveshaft connects to the differential. The differential bolts into the axle housing. The Differential numbers are the most important.
Es sollte eine Kennzeichnung vorhanden sein. Ein Schild sollte sich am Differential befinden. Das ist das Teil, das Sie auf dem Bild haben. Das zweite Schild mit Informationen sollte auf dem Hinterachsgehäuse sein. Die Antriebswelle ist mit dem Differential verbunden. Das Differential wird in das Achsgehäuse geschraubt. Die Nummern des Differentials sind die wichtigsten.
Wiliam
cardan crankshaft, leaking, oil, t444e
