Old 10-21-2021, 10:50 PM   #1
Javvgh's Avatar
Year: 05
Coachwork: Ic
Engine: DT466 2004 225hp 620 lb-ft torque
Rated Cap: 90 passenger
Oil leak RE300 Dt466e
Hello all. While moving the bus around the yard, so I could work on it, I noticed a consistent drip of oil falling. I took the opportunity to clean the motor out with some degreaser so I could find the leak easier. I found the leak coming from what I thought was an oil pressure sensor or temp sensor(red circle), but when I tried to pull the “cable(s)” off it turns out it was more of a rubber hose. So my question is does anyone know what this part is? If so, will swapping it out for a new one fix the leak? And what is the hose? Does this typically need replacement as well?
Also there is a metal tube (very dipstick-tube-like) that just has an open end (well I couldn’t follow it up…) What is this and its purpose?
Thanks!
4433AF91-62D8-4988-AD94-B4134486F068.jpg   641FB9DD-C1F7-48C8-82B3-EE56756C4C55.jpg   EC47E9DF-126D-48B1-89EA-282D35229D28.jpg
Javvgh is offline   Reply With Quote
Old 10-21-2021, 10:58 PM   #2
Year: 1954
Coachwork: wayne
Engine: cummins 12 valve
Pictures are not enough for me to figure out what it is.
But that open tube , I think, is an engine block vent. It is also called “ a draft tube “.
William
Old 10-21-2021, 11:09 PM   #3
Javvgh's Avatar
Year: 05
Coachwork: Ic
I figured the pics were not the best, it’s hard to get the phone finagled in there in the rear pusher. It’s close to the frame which didn’t leave too much room ����*♂️
Old 10-22-2021, 04:51 AM   #4
Is that leaking line going into the side of the pan? Turbo return most likely if it is
Old 10-22-2021, 06:39 AM   #5
mmoore6856's Avatar
Chassis: chevy
Engine: 3116 catapillar
turbo oil is very hot so rubber is not used and it would return to the oil pan right under the turbo. that is too high on the block to be any return so its a supply to something that could include turbo, air compressor and any extra oil filtration added to it. you must follow that hose and see where it goes. the hollow tube is a crankcase breather if its a older engine.
mmoore6856 is offline   Reply With Quote
Old 10-22-2021, 07:24 AM   #6
Javvgh's Avatar
Year: 05
Coachwork: Ic
It didn’t seem like a supply line, to me, due to the dribble of oil leaking? It’s literally a drop every one or two seconds.
It’s def up on the block. Hence my initial thought of some type of sensor. (Temp/oil pressure) in fact it looks like one but the line to it threw me off.
Also the last two pics were rotated 90 degrees so it’s kind of confusing.
Old 10-22-2021, 07:26 AM   #7
Javvgh's Avatar
Year: 05
Coachwork: Ic
Also for another point of reference, that black tube in the front of the first picture, is the oil dipstick tube…. Not sure if that helps anyone recognize what this is.
Thanks again for replies.
Old 10-22-2021, 08:16 AM   #8
mmoore6856's Avatar
Chassis: chevy
sensors screw right into the block. follow the line
Old 10-22-2021, 08:17 AM   #9
mmoore6856's Avatar
Chassis: chevy
do you have a air compressor as it also needs a oil supply line and has no visible return unless its a old belt driven one
Old 10-22-2021, 09:57 AM   #10
many compressors return oil through the bottom plate..
Old 10-22-2021, 07:27 PM   #11
mmoore6856's Avatar
Chassis: chevy
yes thru the drive gear housing but some of the belt driven had a return tube
Old 10-28-2021, 04:21 AM   #12
Chassis: 3500
Engine: GMC
Rated Cap: 8 handicapped
I haven't bothered to think deeply into your particulars - it may be that you have an actual problem - perhaps one that will get worse. My 2 cents worth is that some small oil leaks are not worth fixing. Sometimes the easy way to deal with a minor oil leak is to keep track of it and add a bit of oil as needed.
jackdebear is offline   Reply With Quote
