Originally Posted by mmoore6856
turbo oil is very hot so rubber is not used and it would return to the oil pan right under the turbo. that is too high on the block to be any return so its a supply to something that could include turbo, air compressor and any extra oil filtration added to it. you must follow that hose and see where it goes. the hollow tube is a crankcase breather if its a older engine.
It didn’t seem like a supply line, to me, due to the dribble of oil leaking? It’s literally a drop every one or two seconds.
It’s def up on the block. Hence my initial thought of some type of sensor. (Temp/oil pressure) in fact it looks like one but the line to it threw me off.
Also the last two pics were rotated 90 degrees so it’s kind of confusing.
