Originally Posted by Sp6saz
I got the build sheet like you said they printed it out for me
Great news !
Now you know exactly what parts your bus was built with.
You will notice there are no actual industry or manufacturer part numbers. What I am doing with mine is when a part is required, I call the stealership, give them the last 8 of the vin, I identify the part I need based on the build sheet, they give me the oem part number and I then right that down on the build sheet.
That helps when you are shopping and cross referencing a part.
The build sheet will also tell you what tranny you have and the HP of your motor too…!
