Old 02-25-2021, 09:04 AM   #1
Chassis: 3000
Engine: T444E, Allison 2000
Rated Cap: 71 Passenger, 29000lb
Steel vs Aluminum wheels. Can they be used together?
Does anyone know if steel and aluminum wheels can be used simultaneously on dual axles?
I am planning on upgrading my skoolie steel rims to 22.5 Alcoa wheels. My question is, do I have to replace all 6 wheels? Or can I keep the 2 rear interior steel wheels?
Keeping the two interior rims would save me about $600.
Is anyone aware of any downsides to switching over to aluminum rims?
mrlupr is offline   Reply With Quote
Old 02-25-2021, 09:13 AM   #2
s2mikon's Avatar
Engine: Cummins 8.3
What size is on there now? You will need longer studs. What is your gearing like now?
s2mikon is offline   Reply With Quote
Old 02-25-2021, 09:32 AM   #3
Year: 1974
Chassis: "Atomic"
Engine: DD 8V71
Like s2mikon said, you'll need longer wheel studs. But yes, you can use a steel wheel on the inside and aluminum on the outside...as long as they're the same size. It's actually really common. Dare I say, most common based on what I've seen?
Old 02-25-2021, 09:41 AM   #4
Chassis: 3000
I currently have 22.5 steel rims. Not sure what my rear is.
Old 02-25-2021, 09:43 AM   #5
Chassis: 3000
Thanks for info folks. I would definitely rather save $600 if I can.
Old 02-25-2021, 09:57 AM   #6
Year: 1974
Chassis: "Atomic"
Engine: DD 8V71
You definitely can save on the inner wheels...but don't scrimp on the studs. It will look "close" if you don't change them, but they won't normally be long enough unless you change them out for longer ones. It's really not a big deal to change them.
Old 02-25-2021, 10:20 AM   #7
Super common. In fact, it's more common to find 4 alloy/2 steel then all 6 alloy. Most oem's do this because it's cheaper, like you found.
I highly recommend using wheel guards with aluminum rims. Most oems don't, but it helps to preserve the aluminum, and prevents galvanic corrosion between the aluminum and steel.
https://www.haltec.com/pc/Truck-Wheel-Guards-c220.htm
Old 02-25-2021, 10:22 AM   #8
The only problem doing it this way, is that it makes tire rotation more labor intensive, as you have to dismount and remount the tires from the rims in order to keep the steel wheel in the back. Where as with all 6 being alloy, you can rotate the wheels.
Which might all mean nothing if you're not using all position tires anyways.
Old 02-25-2021, 02:56 PM   #9
Year: 1954
Coachwork: wayne
Engine: cummins 12 valve
Yes
2010 F450/F550, All had inner steel when alloy rears, There is not enough center pilot to locate two alloys on the same hub. If you switch to alloys, make sure you have two or more exposed threads after the wheel nut is torqued. I have heard some quote five threads, but really, from fasteners point of view, two is all that is needed. From a mistake point of view, five or more is better.
William
Old 02-25-2021, 10:13 PM   #10
Year: 2013
Chassis: IC RE
Engine: HT570 / 3500SP
Rated Cap: 4
What I did, inner steel and aluminium on the outside. With centramatics between them. Studs a little to short, this thread (ha ha) reminds me I have to fix that.
ABBus is offline   Reply With Quote
Old 02-26-2021, 12:15 AM   #11
ISAF2009's Avatar
Coachwork: Collins
Chassis: Bantam
Engine: International T444
Rated Cap: 16?
Many vehicles have steel inners and aluminum outers they just look kinda funky sometimes if you rotate properly.
ISAF2009 is offline   Reply With Quote
Old 02-26-2021, 09:43 AM   #12
mmoore6856's Avatar
Chassis: chevy
Engine: 3116 catapillar
you must protect the wheels from electrolysis whenever you attach aluminium to steel. it will weld your wheels together. research this before you commit. they make a thin plastic gasket that goes between the wheels to help slow it down you must use if you go this route. i would just look at chrome wheels instead
mmoore6856 is offline   Reply With Quote
Old 02-26-2021, 09:47 AM   #13
mmoore6856's Avatar
Chassis: chevy
if you buy used aluminium wheels check the date code stamped into the wheel. average life is only 10 years. get them checked for cracks using a dynacheck method as most old wheels will have them
Old 02-26-2021, 09:49 AM   #14
mmoore6856's Avatar
Chassis: chevy
one last note some tire changing machines will wear off the edge of the bead on aluminium wheels. watch for this as once i saw a tire come off as the bead was too thin
Old 03-03-2021, 12:20 PM   #15
Chassis: 3000
Should I be at all concerned about the age of my steel wheels? Is there a date code or something similar I should look for?
I am considering maybe keeping all 6 of them and just getting a decent set of simulators.
I have ordered 6 new tires and wondering if I got ahead of myself.
Old 03-03-2021, 06:12 PM   #16
BriteLeaf's Avatar
Chassis: Carpenter
Steel and Aluminum
Having come from ten years of driving a truck for a living I can tell you that a lot of tire shops will not put aluminum and steel together.
Iím not sure if it is illegal federally or not, but I donít think that itís a good idea.
BriteLeaf is offline   Reply With Quote
Old 03-03-2021, 06:24 PM   #17
Year: 2013
Chassis: IC RE
Rated Cap: 4
Aluminium and steel together on the rear here too. With a centramatic in-between, never had an issue.
Old 03-03-2021, 07:31 PM   #18
mmoore6856's Avatar
Chassis: chevy
yes age is important as aluminum has only a 10 year life average check as most 10 year old aluminium wheels have small cracks. and they have a date code stamped in them however i seen guys buff the stamping out so they can lie about the age. check the date code and if it dont have one walk away. you dont want the wheel to break off and kill someone
Old 03-03-2021, 07:33 PM   #19
mmoore6856's Avatar
Chassis: chevy
not illegal but not a good choice as the mounting face on aluminium is larger than the steel face and thats why they crack so quickly when mated together
