Originally Posted by SkullGirl
Up until the air compressor went out...I was able to do 60 on straightaways. And it would drop to 55 on the inclines I am talking about very slight inclines...like on ramps.
I know the compressor issue you had seems to be related to your current issue, and it may be, only if when it failed, you continued to try to drive with your service brake on and overheated your transmission.
Brown transmission fluid, and revving to 2800 rpms but not getting up to speed are indicators that you have transmission problems. If the brown fluid smells burnt, they may be end of life problems.
Change the fluid and filters. Remove the transmission pan and inspect it for metal and clutch material.
If your transmission has gone up in smoke, for any reason, you may find it less expensive to replace the bus than the transmission.
That really depends on your resources and skills. It sounds like you skills might not be on the transmission swap level, which would mean hiring someone to do it.
A used AT545 on ebay will run around a grand with shipping. Labor could run another 1500 to 2500, depending on who does the work.
You can get a refurbished unit for between 2500 and 5000.
I think if I were in your shoes I would get on public surplus and find another bus nearby.
If you wanted to go as far as New Mexico, We have a 2000 T444E with Alison 2000 or MD 3060 transmission, FREE bus included for $2000. There is really nothing wrong with the bus other than the windshields have been smashed out along with a number of windows. Seats are out. We currently use it to compact our runways on freedomfieldnewmecico.com and for tool storage.
Nobody is bidding on this one in UT:
https://www.publicsurplus.com/sms/au...ew?auc=3608581
You might find it cost effective to run for a bus you can get for a couple thousand and drive it back to where your current bus is then swap your interior and sell the broken bus for parts.
Perhaps advertise it as a DT466 with free bus.
A lot of folks get into bus life because they are under the impression that it is an inexpensive way to house themselves, with the added benefit of being mobile.
The reality is that even if you are a very handy mechanic with your own tools and workspace bus parts are often quite expensive. This is why we have four busses. When we see a deal we buy spares.
We got our last four busses in Phoenix. All from public surplus.
