Originally Posted by brokedown
Can you explain more clearly what the problem you're having is? No throttle sounds like you're describing the gas pedal doig nothing when you touch it, which would be an electrical thing on a t444E. But the responses you're getting are related to the engine not producing normal power. it's unclear to me exactly what problem we're trying to solve.
Of course, I'm french so it's harder. ;)
- When I start the bus, I have the "WARN ENGINE" light on.
- Engine running on idle nicely but nothing happens when I push the throttle pedal / no power.
- I stop the engine. Turn the key back on ignition but I don't start.
- Then I push the diagnostic engine button to see the message on the dash.
- WATER / OIL light is on.
I changed the ICP sensor this morning but nothing improved.
It should be more clear. ;)
