Originally Posted by kevinstotz
I am trying to determine the tire size for the front and rear tires.
I currently have 255/80 in the back and 235/70 on the front.
I don't think this is correct. The rear of the bus is always higher than the front and it slopes forward.
Anyone have any ideas?
The tire size is sometimes recorded on the "ID plate" (the metal plate inside the bus showing the VIM, etc.).
If not, I'd go with 11R22.5. Probably slightly larger than the stock ones, but you'll gain some top speed and ground clearance, and that's an easy size to find. May not be perfectly legal, though ...
