Old 02-04-2023, 04:28 PM   #1
Engine: DT466E/AT545
Trans TEmp Gauge
Does anyone know if this trans temp gauge fit in original dash. it is part# 3519662C1. There appears to be extra spots in the International 3800 dash circled in pics below.
i really rather not have other gauges if there is one that fits.
And I think I have read most people put gauge on outlet going to cooler/radiator. i guess that's the hottest it would be. the inlet from cooler/radiator would be the coolest, right?
And while I am at it maybe EGT?
Anyone seen a gauge cluster with the left 3 and the lower right ones with anything in them. Is there an original location. it looks like these gauges plug into a board and maybe the wires from sender land somewhere else.
GTSailor is offline   Reply With Quote
Old 03-05-2023, 03:11 PM   #2
Coachwork: Jimmy/Corbeil
Chassis: 96 International 3800
Engine: T444E, AT545
I had a pop out circle right above the key ignition area, and to the left of my gear shift. I hole sawed it a bit bigger and just used a generic gauge. Works good!! No matter what you end up doing...its a must. And fyi....what about adding flat plastic and/or trimming to make it fit?
jimmy649 is offline   Reply With Quote
Old 09-21-2023, 02:26 PM   #3
Engine: 7.3 Powerstroke
I have a 1999 3800
My gauge cluster has a trans temp and a current gauge on the right side
40invert is offline   Reply With Quote
gauge, transmission
