Morning
The Vista is all back together. The Alisson 2000 is in, the driveshaft is in, cooling lines. Everything mechanically is done. I had no issues with any of it. Learned a lot and fixed a few things I wouldn't have noticed if I hadn't removed the radiators.
Here she is all installed and finished
Cooling lines are all set
Also nice to know that down the road if I need to replace the radiator due to breakdown I can do it alone, and with a few simple hand tools in about 2 hours or less.
Today I am going to re-install the AT545 on bus 89. I have to wait till Monday to get a replacement Turbo elbow and a clamp as nothing open on weekends carries anything that large. So have to wait to finish re-installing the intercooler till then. But meanwhile I'll get the trans and driveshaft and cooling lines installed.
So basically the Vista is done, save for the wiring nightmare to sort out.
I did post a question in the electrical sub to see if maybe other eyes that aren't watching the transmission thread could point me to schematics or a link to buy a manual or something but no luck there.
So I spent yesterday tearing into the Vista and looking to see if I could find a plug like the one in Bus89 under the dash that the TCM harness plugs into.
And I did.
I also on advice from here and the FB group of bus mechanics decided to go ahead and swap over the ECM's as everyone assures me that while things may or may not work properly or set codes I would not "Fry anything" or "let the smoke out"
So I swapped them.
This is where it gets interesting... and I've got to figure out at least what the wires in the plugs behind the dash do. It seems to be the "key" to everything.
So at this point the post might get a bit long. I'll do my best as well to write down the codes proper but this is where I am weakest is looking at a LOT of little numbers and letters on a page at once...
Also think this may help someone later...most of this is a jumbled mess in my notebook and it may also help me to see it all listed out neatly, double checked as I type it up.
So on both buses there is this plug behind the dash.
This is the vista plug..
Bus 89 has the same plug... some of the wiring is the same or similar numbers which I will get to in a bit.
So on Bus 89 the TCM harness plugs into this mysterious plug. As you remember harvesting the TCM harness from bus 89 required me to cut NOTHING! Nothing at all.
The only thing left on bus 89 are the same 3 plugs above the trans the Vista has, and this plug behind the dash which the Vista also has. No other wiring was disturbed or removed on bus 89.
Meanwhile on the Vista I unplugged Mystery Plug and followed it down to near left footwell behind a panel and it goes to two relays.
But again here is the thing... there are only TWO wires go through the firewall from this relay set. One thick grey (94k) and one thin (94h).
I'm going to bet that this relay set is for the AT545. The thick grey wire has to be power, so the only signal wire going out through the firewall is a single grey.
I cut those two greys (can easily re-splice) and removed the entire harness as one piece easily. So I have a two relay bundle that goes to Mystery plug same as Bus89 does... and sends a single grey wire out the firewall to another plug... I'll get to the pinouts and colors below.
So was getting late... I had earlier in the day installed that silver plug in the vista
Now everything has a mate except I hadn't plugged in the mystery plug yet. Key was off, ECM's were swapped, so I plugged it in. Immediately the ECM gives a relay click from inside... does it 3 times, waits a sec, repeats... I unplugged it and it stopped. Decided to plug it back in and key on and with key on it stopped. Nothing weird happened. Wait to start light and the engine warn light behaved normal.. Naturally doesn't turn over... was not surprised.
So Mystery plug as well as the 3 sensor plugs on the A-2000 that seem to have AT545 ends are what I need to sort.
So on the Vista the mystery plug has the following wires
1. Brown 92A
2. White 94-GA
3. Pink 13J
4. Brown 92
5. Grey 94 (little thicker than the other wires)
6. Grey 24 (thinner)
7. Blue 12A
On the Bus 89 the Mystery plug has the following wires
1. Brown 92
2. Grey 113A
3. White 94-GC
4. Blue 62K
5. Brown 92A
6. Grey 24
On Bus89 before I took it out Mystery Plug pairs to the following wires on the Allison TCM harness plug.
TCM PLUG ---goes to--- BUS SIDE PLUG
1. Pink 13E------ Brown92
2. Grey 113A ------ Grey94J
3. White 94-GC ----- White 92-GC
4. Brown 92A ----- Blue 62K
5. Green 125 ----- Brown 92A
6. empty ----- Grey 24 (not used)
On the Vista the Mystery plug pairs up to the Relay harness I removed of which only a single 94H wire goes out the firewall. It connects to nothing else.
AT545 PLUG SIDE --goes to--- BUS SIDE PLUG
1. Grey 94 ---- Grey 94
2. White 94-GC ----- White 94-GA
3. Pink 13E ---- Pink 13J
4. Blue 12 B ----- Blue 12A
IF I PLUG THE A-2000 TCM PLUG into the Vista Plug I get the following so far.
TCM PLUG ---goes to---- VISTA PLUG
1. Green 125 ---- Brown 92
2. Grey 113A ---- Grey 94
4. White 94-GC ---- White 94-GA
5. Brown 92A ----- Brown 92A
So this is where I am at.
Some notes:
So far on the A-2000 to 98 harness it looks like at least 2 wires are the same
the pink 13E goes to Brown 92 on bus 89 and on both buses there is a wire to the shifter seems to be part of circuit 92 (and possibly 92A, possibly gearshift reverse position?)
The Single Grey 94H wire that goes from the AT545 relay bundle goes into this plug. It has grey/red/yellow/blue wires and the grey passes through the plug onto the grey wire and down towards the trans (haven't chased it all the way yet, but it goes right down the rail towards)
Naturally these wires are the ONLY ones on the bus seem to have no ID number/letters. Grey passes on to the relay.. other two wires are I believe data wires... black J-something numbers... I saw more of them down below and capped with a red plug and a black plug... Was told on the FB group these are data wires and no touch lol
Here are those plugs, but I don't need to mess with them for what I am doing... I am only showing them ... and there are other J black wires all over (I can get the number and edit when I go out in a few)
The thick grey wire going TO the relay bundle came from this plug... weird it has grey, green, and light brown wires...
Other side of the plug has three thin wires that all have been soldered and heat shrunk (looks old, possibly factory) onto the single thick grey wire fed the relay.
Other note concerning the sensor wiring. On both buses I have the same style plugs. so everything on the A-2000 plugged right on up to the 98 harness was dangling. I thought was odd, but with the plug and play harness on top thought maybe since the 03 could have had the At545 then the A-2000 harness came with plugs for that OEM harness?
I'll post in a bit the colors/labels. But no plugs are left except the Modulator plug dangling.
So My goal today is to reinstall the mechanicals on bus 89 and just get that out of the way..
Monday make some calls, see if maybe the dealership or even calling Thomas may yield some answers on that mysterious plug.
Chris if you can help interpret any of this I would surely appreciate the help.
If you can point me to where to buy a book or schematic that would help also.
Any thoughts from anyone following also appreciated. I hop you are enjoying the read. It is all about fun, and learning.
I feel I am getting close though, sorry if it's a bit of a jumbled mess of a post
cheery day
dave
