07-21-2021, 05:15 PM
Chassis: S-1800
Engine: NAVSTAR DT 466
Rated Cap: 49
Transmission removed now bus no start
Hi AllStars,
From a couple posts ago y’all said it’s ok to run the dt466 without transmission low speed, short duration. I went to start today, and all I got was a healthy click from the solenoid by my left elbow. There’s no indication that the starter is engaged at all. I did tighten starter after transmission removal, and hadn’t disconnected it.
I took remedial action and hit the starter with a soft sledge, and ran jumper cable from the transmission ground to the bell housing. Then was out of ideas, and thinking about beer.
It’s in neutral. Foot on brake.
Do either of the sensors need voltage to allow the starter to engage? Something else?
As always, all suggestions and ideas greatly appreciated.
Doug
07-21-2021, 05:44 PM
Is there a transmission position sensor?
07-21-2021, 08:50 PM
Chassis: F33695
taking your transmission out removes your neutral start system, you should be able to jump the solenoid and get it to start.
07-21-2021, 09:24 PM
Year: 1954
Coachwork: wayne
Engine: cummins 12 valve
no crank...mechanical dt466
1) make sure the batteries are around 12.3 volts or more...12.6-12.7 would indicate fully charged battery
2) good ground connection to the engine block,dont think jumper cable is gonna be enough
3) good ground to the body - the starter solenoids are probably grounded to the body/chassis though I have seen one where the body of the solenoid was grounded to a bus bar
4)when you turn the key to the start position batteries should stay above 10 volts I really like to see 10.5 v when cranking
go from there
william
07-21-2021, 11:51 PM
Rated Cap: 31,800 pounds
Transmission removed I'm with TRANSMISSION POSITION SENSOR signal isn't present so power is not sent to the starter.
07-22-2021, 08:24 AM
Chassis: International 1753
Engine: 6.9 International
As others have said, with the transmission removed, and no steps to address the neutral start switch, the bus won't start with the key.
Either jump the starter solenoid with the key on, or install a jumper wire into the connector for the neutral start switch.
With an at545 or mt643, it will be a 2 wire connector that was located up and behind of the shifter on the transmission. It should be pretty easy to find.
07-22-2021, 09:13 AM
the neutral safety on that should be 2 single pin round barrell connectors. if you plug those together that bypasses the neutral safety and lets the engine start.
07-23-2021, 07:33 AM
Chassis: S-1800
Rated Cap: 49
Again, you guys come through in a pinch. I’ve got appointments today, but will get on all this today or tomorrow. I’m moving the bus Tuesday and it’ll be such a big help to have, you know.....steering and brakes.
Thank you. I may learn enough to be able to help others on here some day.
07-23-2021, 08:07 PM
Moving how far? Around in a field or onto a public roadway?
I hope not on public roads unless it's being towed with a commercial tow truck set up for such things in which case a running engine isn't needed.
07-24-2021, 05:40 PM
Chassis: S-1800
Rated Cap: 49
Got er running
I dabble in repairing guitar amps, so have some little jumpers around. Just jumped the male and female connectors on the two wires going to the sensors going to the transmission, and she fired right up.
Tow truck is coming for the big move ( all 7.7 miles ) next week, but it’ll be nice to have power steering and brakes for positioning it here and there in the yard. It’s really hard to get it moved around without power steering and brakes, and y’all know.
I got evicted from the campground I’ve been in for 8 months because the owner told me some customers don’t want to be near “that old blue bus”. I told her she doesn’t want people in their fancy rigs if they’re upset by my bus. They’ll just complain about something else. But I’m going to a friends private yard, so it’ll be better anyway, and cheaper.
And, the owner and all her minions at the campground just came down with covid. Justice? karma?
Anyway, avoid Blue Sky campground if your in Mtn View AR. Not Skokie folk.
Maybe it’s me, maybe my old dogs.
Couldn’t be my bus?
Anyway,thanks again for the help. Next- transmission upgrade!
07-24-2021, 07:38 PM
Year: 1954
Coachwork: wayne
Transmission
What cha gonna do? There is 653. And a couple of 643 around. Might be a manual trans or two also.
William
07-25-2021, 04:02 PM
Chassis: S-1800
Rated Cap: 49
I’m going to avoid manuals just to reduce machining. I’m looking for land, and hope to buy some soon but will still want the bus for local travel and eventually to take OT touring National Parks and wilderness areas. Thus want to avoid another 545..
I haven’t heard of the 643 or 653, or did and forgot. Once I’m moved I’ll do the research and find the closest locking trans that has even a short warranty. 1986 bus so I’m not going with something with electronics.
Fall off that bridge when I get to it. This week is the move, and of course it’s gonna be 97 degrees.
07-25-2021, 08:50 PM
There are no easily fitting allison overdrive transmissions that are overdrive . Going to a 643 gives you lockup but still 1:1 top ratio like the 545. A 663 gives you a granny gear and then 4 normal gears but again top gear is 1:1
They are beasts of transmissions and very durable plus with lockup you make much less heat and the bus will pull harder in 3rd and 4th . I already have decent Highway gears in my dev bus so the switch to 643 from 545 was lateral in speed but the lockup makes the bus drive a bunch nicer . I also like the firm solid shifts a 643 has. You know when it shifts !
07-25-2021, 09:50 PM
Year: 1954
Coachwork: wayne
653 allison transmission
This is like a 643 and has one lower gear. It is a five speed mechanical transmission. the 643 and 653 both are one to one drive in top gear. Lock up on the upper gears like the 643. LKQ still has some of the rebuilt 643 last time I checked.
william
07-25-2021, 09:53 PM
really happy with my LKQ reman 643.. no issues 2 years in on it now
07-26-2021, 08:47 AM
william
They had quite a few as of a month ago. Getting one freighted to Ohio from marshfield MO was going to cost more then the transmission though........
I guess I should just bite the bullet and rebuild the 643 I've got.
YMMV
07-26-2021, 09:10 AM
YMMV
I was probably within 100 miles of them this weekend I couldve picked it up and brought it back... when i got mine I drove out and they loaded it up into my pickup for me..
07-26-2021, 09:15 AM
Chassis: S-1800
Rated Cap: 49
Lots of options. Once I’ve moved this week I’ll dive in. There’s a transmission place in Little Rock, still a few hours a way, that has some transmissions. I was pretty happy topping out a 58mph downhill. So I’m not worried about speed. I want something that’s strong. I want to take this bus around the country a few times.
Once I find one, I’ll research the posts , but I’m sure I’ll have more questions. I know where to go for answers!
07-26-2021, 09:35 AM
Shizzlesticks. I would have paid you for doing that. I just don't have the day to burn to drive out there and back. And I really don't want to pay 1000 bucks to ship a 500 dollar transmission. The rebuild kit is 600 bucks plus my time.
Let me know if you swing out that way again.
