Old 10-11-2021, 04:01 PM   #1
Transmission identification help.
Hey guys!
First post here! Appreciate any help in advance🙏
Just got our bus home, I'm just trying to figure out which transmission I have?
Is this enough information?
07 International CE300 PB105
06 D220 Dt466 7.6L
Vin: 4DRBUAAPX/B355217
Thanks in advance!
Dre@mweavers is offline   Reply With Quote
Old 10-11-2021, 04:57 PM   #2
Mountain Gnome's Avatar
Chassis: TC1000 HandyBus
Rated Cap: 26 foot
Contact the International dealer with the VIN and they should be able to tell you.
Look at the Sky; look at the River. Isn't it Good?
Old 10-11-2021, 05:02 PM   #3
Thanks so much.
Old 10-11-2021, 05:42 PM   #4
Ronnie's Avatar
Engine: 345 international V-8
There will be a tag on the side of the transmission that will tell you as well.
Old 10-11-2021, 06:09 PM   #5
I crawled under, was a bit dirty and cold at the time lol. Also I've got an injured eblow so was having trouble maneuvering under there..
Where should it be?
Old 10-11-2021, 06:19 PM   #6
what kind of Shifter do you have? pushbutton with digital display? if so then its a 3000 series (most often the MD3060)..
if you have a handle with no digital display.. and it has R N (D) D 2 1 or R N D 4 2 1 then you have an allison 2000 series, likely a 2500 PTS on a CE300.
that bus is too new to have an AT545 or MT643
Old 10-11-2021, 06:21 PM   #7
ewo1's Avatar
Like He said, contact any International dealer parts dept, ask them for the build sheet on the bus.
It will give you all the specifics on that part
They need the last 8 digits of the vin number in order to look it up.
This is what they use when you call looking for parts. It's why they always will ask for the vin so always have it handy!
Old 10-11-2021, 07:49 PM   #8
Push button w/ digital display.
Old 10-11-2021, 08:16 PM   #9
Gotcha! Dually noted!
dt466, identification, international, new bus owner, transmission
