Temporarily Resolved
Of course, after posting my long novel I got her started. Here's what I did.
Because it only happened after changing the fuel filter that I absolutely couldn't get her started I was still of the opinion that it was fuel related.
I read several posts online to absolutely avoid ether to start most diesels, unless the manufacturer recommends or oks it. I also read to NEVER use ether if your diesel has glow plugs or a pre air heater for the engine.
I read more. I didn't want to try ether...
Then I called around several tow companies to see what they would charge to tow me. It couldn't be that bad, we're only talking like 10-12 miles to my storage unit. Well, the cheapest was $380!
As a last resort, ether it was.
I disconnected the glow plug relay first though. Because ether burns faster it can throw off timing causing early detonation, which is bad for the engine. After thoroughly researching I decided the risk was minimal.
I sprayed about half a second of ether while my son cranked the engine over. Another safety measure is to do it while the engine is cranking. Minimize your use of ether. I read one to three seconds only. I thought I would go even less, and it worked.
She fired up immediately, and ran great immediately. I think I must have had most of the air out of the fuel lines at this point. Happy dance! High fived the boy and prepared the bus for travel. Putting things away, air filter housing back on, etc.
Then I drove her to the storage unit without event. Once I had her parked I tried to start her again just for fun. Nothing. The mysterious short somewhere was in effect and I decided to save that for another day.
I still have work to do, but I don't mind. That's one reason I bought her! It did make me realize I need scanning capabilities, some spare sensors, and I may let International change the next fuel filter in a couple years or 15K miles... probably not.
