Old 12-09-2023, 09:11 AM   #1
Engine: DT-466e, AT-545
What fluid for AT-545 transmission, and how much?
Just noticed my AT-545 fluid is a bit low, or really lowÖ donít know yet. I have put Valvoline ATF in it before, but now I canít find a source for why I used that fluid and Iím questioning myself. Is it a problem that it has this fluid in it? Should I just top it off with the same fluid? Also how much does it take?
Beeb2 is offline   Reply With Quote
Old 12-09-2023, 11:58 AM   #2
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
how much did you put in of the valvoline?
you should be looking for a fluid comparable to TRANSYND.
Old 12-09-2023, 02:16 PM   #3
Back in 2020, I had my transmission line leak and I lost most of not all of my fluid. This is what I replaced it with. I used about 3 gallons back then. Iíve driven from New Mexico to Florida and back since then.
Old 12-09-2023, 04:13 PM   #4
Year: 2008
Chassis: IC RE (PB30500)
Engine: Maxxforce DT
AT-545 call for Dexron-II on the spec sheet, I'll put a scan of it below. The Valvoline Multi-Vehicle Full Synthetic ATF meets Dexron-II standards according to it's own spec sheet, I'll upload the pdf for it. It's perfectly fine to use that fluid.
Under oil type you will see Dexron-II is recommended
US_Val_MLMultiVehicle_ATF_EN.pdf
On page two under GM it has Dexron-II qualifications
If that's the fluid you can get ahold of easily. Keep on using it.
2008 IC RE 40ft w/ Maxxforce DT and Allison 3000 PTS for fulltime living w/ a family of four.
Clouse House is offline   Reply With Quote
Old 12-09-2023, 08:56 PM   #5
Awesome. Thatís a relief. I definitely freaked myself out this morning when I couldnít figure out why I started using that fluid.
at-545, fluid, question, transmission fluid
