Engine is a 1996 DT466. In replacing the exhaust manifold on the bus, I got a little aggressive with the wrench and smacked into this unknown sensor, which promptly busted. I wasn't in a time and place where I could do the job correctly, so tried gluing the plastic housing together with JB Weld but it didn't hold up. IIRC there was a spring inside the plastic casing.
Anywho, I backed it out of the hole and coolant started trickling out so I assume its some sort of coolant sensor? From googling around it seems like maybe its a Engine Coolant Temperature sensor, though the temp gauge in the cab still functions. Maybe its the overheat sensor?
Location is passenger side, toward the front of the engine. There appear to be 2 of them, this is the upper one.
Anyone know what replacement part I should be ordering?
