Depending on the axle (to locate this tag) it might be in one of two places, assuming your rear axle is a Dana/Spicer. Info on the axle itself might be on the build data sheet. First place to find the axle tag would be on the axle housing, on the right side facing the front of the bus. The other place might be in the differential carrier itself, near where the driveshaft enters the rear differential.
If you can’t find the build sheet in your bus, am international dealership or rush truck centers might help. Or this
https://www.skoolie.net/forums/f37/n...ase-38729.html
