Old 05-07-2024, 12:38 PM   #1
Engine: DT-466e, AT-545
Where/How to replace AT-545 shift lever
Hey all,
My shift lever just broke while driving. Anyone know where I can find a replacement, and how to find the correct model? Photo below.
Also, how hard is it to replace this myself?
Beeb2 is offline   Reply With Quote
Old 05-07-2024, 12:43 PM   #2
its a standard shifter, looks like an IH 3800.. 4 bolts hold it into the dash and there is a cable connection and a wire (for the backlight).. and thats it..
you cxan find them used everywhere.. vaanderhaags, truck parts inventory.. any heavy truck / school bus junkyard..
that said, if you were really having to pull on your shifter so hard that the handle broke off you may need a new shift cable.. you shouldnt have to exert much force to shift...
Old 05-07-2024, 12:45 PM   #3
Sweet. Thanks!
I didn't have to exert force at all. I don't even know how it happened. It was like it just dissolved in my hand while shifting and suddenly I had to shift by pushing the little pin in!
Old 05-08-2024, 10:02 PM   #4
nikitis's Avatar
Rated Cap: 29
Yeah the side button pushes that pin which unlocks it out of its current gear and allows you to move the stick.
Could be a cool opportunity to custom make you an end for uniqueness.
Old 05-18-2024, 04:51 PM   #5
I may have a shifter that will work. It's from a 1997 c6500 with an allison 545
Jon6089 is offline   Reply With Quote
Old 05-19-2024, 11:09 AM   #6
Thanks. I was able to pick one up from Vander Haags. Cost me about $200. I haven't installed it yet, and now am having bigger issues with my bus, but that's another post...
at-545, help me, replacement shift lever
