Old 02-07-2020, 03:32 PM   #21
Meathead's Avatar
Engine: 3126b 210hp
Im late getting here but your belt should be Napa #257345. And yes, at first you think she ain’t coming off, but it does
Dave
“Once in a while you get shown the light in the strangest of places if you look at it right.” -Robert Hunter
Meathead is offline   Reply With Quote
Old 02-07-2020, 03:56 PM   #22
Originally Posted by banman View Post
I would get the correct belt from Freightliner and see if you can get it over the balancer -- just cut the old belt off.
If you still have to remove the balancer -- be sure and use a correct puller for it -- I know it looks massive and indestructible but you don't wanna damage the bonded rubber.
The old belt is hilariously short of slipping over the balancer.
Balancer is off, Freightliner has NONE of these belts in FL. Going to Oreilly's.
The balancer doesn't require a puller. I got it off in five minutes.
Roll Your Own Build Thread
Old 02-07-2020, 03:58 PM   #23
Originally Posted by Booyah45828 View Post
All the ones I've done, the damper didn't have to come off. On the ones with the larger damper, it's definitely tight, but it will slip over the balancer if you flip it so the flat side of the belt is inside.
Oh, and grease the O-rings when you put them in the grooves, this will help keep them in place when you are installing the pump.
I'm not installing a pump. Just changing the belt.
two other folks good at working on stuff tried to get it off, too.
It wasn't even close at all.
Old 02-07-2020, 05:29 PM   #24
Job is done. The only thing left to mystery is the torque specs for the damper's outer ring. There are 8 bolts. I torqued em to 40. They felt about that tight. I can't find the spec anywhere even adept ape doesn't know.
I may go back out and torque them to 55 or so, idk.
Spent most of the day in Kubla's MCI. That thing sure rides nice. Too big for me, but its a cloud on wheels.
Edit- Glad I stopped at 50 lbs. spec is 40 on the 8 bolts on the damper for anyone else who's wondering.
Old 02-08-2020, 06:34 AM   #25
This is what the old belt looks like-
Old 02-08-2020, 09:27 AM   #26
The new belt installed.
Old 02-08-2020, 11:04 AM   #27
Chassis: International 1753
Engine: 6.9 International
Lol, yeah there's no way you were getting that over the balancer. I wonder if that's stock, because all the ones I've seen were around 12", and they didn't have the slots on the inside. But a google search shows balancers similar to your so IDK.
Don't feed the trolls.
Old 02-08-2020, 11:16 AM   #28
I think folks are using larger-than-stock belts to get them on and off without removing that damper.
The damper isn't a big deal. Its a bit awkward working it up from underneath but its easy enough.
The old belt says Caterpillar on it and judging from the condition of it and the rest of the bus I really believe it to be THE original belt that came on this engine. I'll never really know, though. When I do a search it comes back as notched v-belt.
Now I'm just waiting for the new coolant tank. Once its on the bus I'm going to flush the coolant a few times over and put the red elc stuff in it.
Old 02-08-2020, 01:29 PM   #29
Cool. Was thinking the balancer would be harder to remove -- good to hear it ain't...
Thanks for the pic/measurement!
The weight must be a little awkward though...?
David
The Murder Bus
banman is online now   Reply With Quote
Old 02-08-2020, 01:32 PM   #30
Its not too bad. Just one handing it while you start the bolts is a little awkward.
Having done it now I could do it again in a half hour or less. But man is it daunting when you're not expecting that added step!
Old 02-08-2020, 11:13 PM   #31
Oh exactly -- that's the kinda surprise on the side of the road late at night that brings a grown soul to tears...
David
The Murder Bus
Old 02-09-2020, 12:07 AM   #32
Yep.
That's why bus maintenance is so important. If you keep up with it you reduce the chance of that late night roadside bummer plus if you do end up on the side of the road you'll be familiar enough with stuff to get it done without as much fuss or stress.
Old 02-09-2020, 09:08 AM   #33
Chassis: chevy
Engine: 3116 catapillar
Rated Cap: formerly 71 now 2 or 4
[QUOTE=EastCoastCB;372249]I'm not installing a pump. Just changing the belt.
It wasn't even close at all. i
had some of these too
mmoore6856 is offline   Reply With Quote
Old 02-13-2020, 02:52 PM   #34
You may want to hold off on the coolantchange until after you diagnose the compressor. If you have to pull the compressor, you will have to drain the coolant.
Old 02-13-2020, 03:13 PM   #35
Yep. I'm not averse to draining it again, too.
Old 02-14-2020, 03:45 AM   #36
Truthseeker4449's Avatar
Chassis: HDX
Engine: CAT 3126
This is valuable information to know, my own compressor isn't doing too good either. It works, but the build time is too slow, especially at idle or even fast idle. At high rpm it works ok so no drivability issues so far but I sure as heck don't want to have to rig something up on the side of the highway.
Where does it feed coolant in? Is there a hose? Does it go through the front cover?
Truthseeker4449 is offline   Reply With Quote
Old 02-14-2020, 09:06 AM   #37
Chassis: chevy
before you put the pulley back on screw a short stud in the top hole to help hold it and guide it on. install a few bolts then remove the stud. lots easier to install.
Old 02-14-2020, 09:49 AM   #38
Not really needed.
