Old 09-02-2020, 07:59 PM   #41
Chassis: International 1753
Engine: 6.9 International
Originally Posted by RolesvilleMarina View Post
reading this makes me cringe when I realize how close I came to doing some of these things... like panicking when the torque converter was just shy of snugging up, and you told me relax and just scootch it and it was supposed to be this way.
especially during my swap when I thought the flywheels needed replacing too and I basically would've grenaded both motors
That's par for the course for the first time. If you've never done it, how would you know? Biggest thing when attempting something the first time is to ask others any question you have, and don't just assume you know what you're doing.
It makes me cringe knowing somebody somewhere installed a torque converter wrong, started and ran the bus long enough to see no fluid flow, and then didn't remove the trans pump and input shaft to inspect for any damage. I'd bet the farm that there was damage, but what do I know
Old 09-02-2020, 08:24 PM   #42
Chassis: Vista 3600
Rated Cap: 24000 lbs
10-4
I asked a LOT of questions and wasn't afraid to look stupid, and in some cases have to apologize for coming across an arse as I was figuring out things
slow and steady was indeed the key, and some humility
RolesvilleMarina is offline   Reply With Quote
Old 04-02-2021, 08:17 PM   #43
Do you have any pics of the flywheel setup you used for the 643? Trying to do this swap now and canít seem to find the correct setup
Tmullins96 is offline   Reply With Quote
Old 10-01-2022, 03:56 PM   #44
Originally Posted by DtotheAmbrose View Post
The parking brake arrived and looks great. There is a little bit of some blue paint so this probably came off an intl powered truck originally. It is much bigger than the AT545 brake, looks to be 3-4 inches in diameter and about 1 inch wider.
Where did you find the parking brake ?
Trav5122002 is offline   Reply With Quote
cat 3116, mt643, trans swap
