Old 06-18-2021, 04:23 PM   #1
Year: 2006
Chassis: Saf-T-Liner EF
Engine: Cat C7 + Allison MD3060
Cat C7 rattling/knocking at specific throttle level
Caterpillar C7 engine owners: do any of you have issues with a knocking/rattling sound at certain levels of throttle? This only seemed to happen when going up a slight incline at 65mph, the top speed of the governor.
https://youtu.be/4mCHMME9N0A
dbsoundman is offline   Reply With Quote
Old 06-18-2021, 05:15 PM   #2
Chassis: TC/2000
Engine: 5.9 Cummins 12-valve
Rated Cap: 1
The idler pulley would be the first thing I would check. Or the fan bearings since it's when the fan should fully engage.
BamaBus is offline   Reply With Quote
Old 06-19-2021, 10:20 AM   #3
DtotheAmbrose's Avatar
Coachwork: Century
Chassis: C5500, Bus not a School Bus
Engine: 3116 9YN, CAT, 250HP
Rated Cap: 30k
I had the tensioner pulley do something similar only under heavy load pulling hills. It looked fine visually when the truck was idling, when the belt was removed you could really tell it was dying.
DtotheAmbrose is offline   Reply With Quote
Old 06-19-2021, 11:54 PM   #4
Simplicity's Avatar
Coachwork: IC / Amtran
Chassis: 3000 / 33' Flat Nose
Once it has started to knock, what do you do to make it stop?
What speed does it start to happen?
While it could be a pully, I'm wondering, since you said it starts knocking at it's governed speed, if it's trying to "govern" the speed and it's "knocking" against that governor limit??
Steve
Old 06-20-2021, 09:21 AM   #5
Year: 2006
I think itís more of an RPM/torque level combination. It will happen briefly when accelerating from a stop to say 35-45 mph. It happens consistently when climbing small inclines at the governor limit I think just because I hit that magic RPM level. My tach doesnít work but I have a BlueFire so I plan to monitor it next time I go for a drive.
Basically, the way to get it to stop is to take my foot off the gas, or get the transmission to downshift.
Old 06-20-2021, 01:42 PM   #6
Chassis: TC/2000
Rated Cap: 1
You're right. The tensioner and/or it's pulley is more likely.
Old 06-21-2021, 07:24 AM   #7
sounds like a pulley or engine accessory to me.
Wear A Mask- Stop the Spread!
