Old 02-23-2024, 02:14 PM   #1
Chassis: VIN = 1T7HR3B2311090770
Rated Cap: ~72
Cat er3126b210
Hello folks,
I am hoping for a reality check here:
That engine listed above needs only larger orifice injectors to get to 250hp, correct?
I can not find anywhere the usual coolant pressure and flow rate, I need that to size a heat exchange and boost pump to move the coolant through the engine and/or domestic hot water heat exchanger.
Hoping for help, and thank you in advance.
TaliaDPerkins is offline   Reply With Quote
Old 02-24-2024, 07:59 AM   #2
Rated Cap: ~72
The goal RE a pump is to size the pump for head and gpm.
« 2002 3126 | - »
