I'm doing the same thing. I bought the tubing, but haven't fully figured out the rest.
My thought is a tray, like a metal gutter for the hose to lay in. But, it would need to be flexible enough to angle up from under the bus and then run over the cross members.
Maybe metal flashing. It would roll off the roll and pull nicely across the crossmembers. Easy to rivet through, and after laying the hoses on it, should be easy to wrap it around the hoses.
I'd rivet brackets to the flashing and secure the brackets to the cross members.
I figured that would provide support and protection from the elements. I'd probably lay rubber on the bottom of the flashing for insulation. Maybe even put a layer of something over the top, then use zip ties to hold it all in.
What were your ideas?
Steve
