Originally Posted by Peterjk
Ok, so what I thought was the secondary a Baldwin B5134, was actually the a coolant filter, located directly behind the oil filter.
So looks like there is 1 oil filter [CAT 1R-0739] and 1 fuel filter [CAT-1R-0751] on this engine. Makes things simpler.
That's it.
hmmm, so no water separator filter device??? I'd actually be surprised at this. Maybe someone else can chime in with an opinion too, but I don't recall ever seeing a modern diesel bus with only 1 fuel filter. I can't even think of any of our fleet of trucks not having 2 filters. Sure, I could be wrong but I'd sure hate for you to be stranded over an overlooked simple piece of maintenance that you thought was taken care of.
You might want to do yourself a favor and get under the bus and follow the fuel line from the injector pump back to the tank looking for a filter. I'd think it should be quite obvious if there's one under the bus, meaning it shouldn't be hidden or anything like that.
