Old 05-09-2020, 07:59 PM   #1
DtotheAmbrose's Avatar
Coachwork: Century
Chassis: C5500, Bus not a School Bus
Engine: 3116, CAT, 215HP
Rated Cap: 30k
GMC Topkick/Kodiaks
Has anyone here had to deal with an in-op tachometer in a Topkick or a Kodiak in the 91-97 3116 models before?
Key on the tach hops a little bit. Cranking over it moves as well but once the truck is running nothing.
I thought I had a wiring problem at the alternator so I installed a new one and new plug. No difference. I picked up a used cluster from another diesel model and no go. The wiring diagram doesn't show any connections that I havent inspected.
I am hoping there is a test method I can use to sort out of I have just have 2 bad clusters or there is something else going on.
TIA
DtotheAmbrose is offline   Reply With Quote
Old 05-09-2020, 09:06 PM   #2
CHEESE_WAGON's Avatar
Year: None
Coachwork: None
Chassis: None
Engine: None
Rated Cap: None
Sounds like you covered the basics. While it's certainly possible that both your original and the replacement cluster were bad, I don't think it likely unless it is a common problem to that model. There is always a possibility that there is a difference in signal between year models. Otherwise it would appear that whatever triggers tachometer from either the injection pump or elsewhere is fried.
"Cheese Wagon" <anomaly.va@gmail.com>
Former owner - 1989 Ford B700 64-pass Blue Bird (Rest In Peace, Cheese Wagon)
cat 3116, tachometer, topckick
