Hey all an update.
Changed the oil, pressure shot up while hot to 35 psi or greater at idle.
I figured out why the oil loses lubricity quick on this engine.
So, when the engine gets warmed up it operates just under 210*F (at the high end when at my max speed of 55 mph) which is way too hot for this engine. For reference, i live in Central GA.
I cleaned the radiator(s) with simple green and pressure washed them and it didn't really make a difference.
So I think I need to change the Change the coolant, then thermostats, and check the water pump. The fan turns on and moves when it needs too.
Thinking of grabbing this kit and just swapping them out. I think one of the two thermostats dont open correctly
https://www.raneystruckparts.com/cat...RoCuOUQAvD_BwE
Any idea which coolant to use? I checked the troubleshooting PDF i have for on road c7/c9 and its not clear. (I have all the pdf books from cat for our engine if anyone needs) Same with thermostats.
I appreciate your guys help.
USAFbus
