Old 02-07-2021, 02:48 PM   #1
Rwnielsen's Avatar
Chassis: TC2000, 40' MPV
Rated Cap: U/K
12v 5.9 RPM
I have a '98 Blue Bird with a 5.9 and a B-300 trans. It's showing almost 2200 RPM at 65 in 5th. I seem to remember max RPM is around 2600, is that correct? That would make 65 - 70 mph within the safe range?
Thanks
Rick
Rwnielsen is offline   Reply With Quote
Old 02-07-2021, 05:25 PM   #2
Ronnie's Avatar
Engine: 345 international V-8
max rpm in what way? The engine can be run up to 3200 without trouble, 4000 if you change valve springs. However in a school bus it is likely governed around 2600 rpm as you mentioned. 2200-2500 is a real good cruising speed for this engine for long life and decent fuel mileage.
Old 02-07-2021, 05:47 PM   #3
Rwnielsen's Avatar
Rated Cap: U/K
Thanks for the info. I'm not planning on racing anyone but if I get up to 70 mph I'll still be in the safe zone
Old 02-07-2021, 11:08 PM   #4
Year: 2013
Chassis: IC RE
Engine: HT570 / 3500SP
Rated Cap: 4
Engine-wise, yes.
ABBus is offline   Reply With Quote
