Old 01-25-2022, 01:17 PM   #1
Chassis: TC1000
5.9 12 valve wont turn over
So when i turn the key on the bus powers up fine, when i turn it over it just constantly clicks over and over again. I think it could be a battery issue but dont understand why everything powers up, could be a lead issue but they dont look corroded or unsecured, which leaves me to believe its a starter issue in particular the solenoid, any thoughts?
Malizzle is offline   Reply With Quote
Old 01-25-2022, 02:27 PM   #2
Year: 1954
Coachwork: wayne
Engine: cummins 12 valve
i have a tc2000 with a 12 valve
do you have time to telephone me?
do you know how to use a volt meter?
do you have a 2nd person to help with testing?
william 7852077600
Old 01-25-2022, 03:09 PM   #3
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
check battery voltage
clean cable ends
and then look at the starter solenoid.
Old 01-25-2022, 03:38 PM   #4
ewo1's Avatar
Originally Posted by Malizzle View Post
So when i turn the key on the bus powers up fine, when i turn it over it just constantly clicks over and over again. I think it could be a battery issue but don't understand why everything powers up, could be a lead issue but they don't look corroded or unsecured, which leaves me to believe its a starter issue in particular the solenoid, any thoughts?
To help you understand a bit, lights and appliances need a very small amount of current flow.
To start the bus, it requires a HEAVY amount of current.
So your battery might read 12+ volts but if it has lost it's current power/capacity then all you will hear is a clicking sound.
That is why you might feel it is not the batteries but like everyone has suggested already, it is more than likely you need to charge or replace your batteries.
Old 01-26-2022, 07:40 AM   #5
Chassis: TC1000
Ok I will check it this weekend!
