RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 03-02-2020, 10:15 AM   #1
Chassis: 2002 Thomas MVP FE
Engine: 5.9 Cummins, 24 valve, AT545
5.9 24v idle speed in a Thomas.
Okay I’ve got a 2002 Thomas MVP-EF with a 5.9 24v Cummins and an AT545. It’s not the best combo but it works for my needs. Anyways, the tach is dead. Got a replacement to install but I’m not sure what the idle speed or high idle speed is on this engine. Does anyone have a similar bus that can help clue me in? I just want to make sure it’s calibrated correctly.
Thanks.
xrolo98 is offline   Reply With Quote
Old 05-30-2020, 04:22 PM   #2
Chassis: RE300
Rated Cap: 76
IIRC, the idle speed is 750 - 800 RPM when in gear. It will be lower when in neutral, probably 600 - 700.
jjaj823 is offline   Reply With Quote
