Hello all!
In a few weeks I am planning on taking my 2003 Blue Bird All American on it's first trip! It'll be a short drive, hour and a half, to my parents place for the weekend. Figured that's a good short trip for it. While it's been in the conversion phase, it's been sitting for close to 2 years (Dec 201
. I want to make sure I'm all good and prepared for a little trip and that nothing is going to happen along the way. I've got a 5.9 24v campaign 0504 and a AT545 transmission in there. Here's my list of things I know I need to do beforehand:
- Oil and filter change
- What oil and filter should I use for this?
- Fuel filter change
- Fuel water separator filter change
- I read that it should be located in the inner left frame rail, behind the battery box, but I didn't see it down there. Still need to locate it.
- What sort of filter should I use here?
- Fresh diesel
- I'm currently sitting at a 1/2 tank, and that's since Dec 2018. I was told I might have algae there. Was planning on topping off with fresh diesel before the trip.
- Tire change
- All 6 tires are pretty low on tread, and the back 4 have already been retreaded once already. Just going to start fresh here. Big expense, but I'm more comfortable getting these new ones on.
- Top off coolant
- I lost about two gallons or so when I removed the heaters from inside the bus. What kind should I top off with?
That's all I've got so far. I'm having a semi truck mechanic come out to the bus to do the tires, and while they're out I'm going to have them give the bus a once over to make sure nothing too serious is wrong with it.
Is there anything else I should add to my list, or make sure the mechanic checks out while they're out? I plan on making short trips around where I store the bus beforehand JUST to make sure nothing major goes wrong while close to home. Appreciate the help!
