Got a 97 BB FE with a 5.9 Cummins. The S belt went by-by, and my electrical/mechanical fan stopped working. It was last fall so cool weather to travel, so just added a couple of electrical fans in front of the rad for safe measure. Warming up and in travel mode, diving in to fix this.
Did a test on the fan clutch with a 12v jumper wire, cant get the solenoid to move, i can see shreds of fan belt behind the pully, thinking it took out the wires behind the clutch.
Fan Clutch. that year of engine, I can get the replacement clutch, $$$$. All kinds of "mechanical Viscous type clutch" out there for the 5.9.
Can I convert to a Viscous clutch? Better/Worse? Same fan-blades?
Why am i thinking of changing? Cost, simple system, avaibility. fan belt shouldnt hurt it if the belt goes out again, (my bad on that, should have changed the belt sooner)
So, Viscous type clutch fan.....yes no.....hell no?
Thanks
Russ
