Old 03-07-2022, 01:09 PM   #1
5.9 L Cummins diesel transmission overheat
All of a sudden if I drive my 2004 bluebird bus, the transmission temp Guage shoots up past the 400 mark. As soon as I noticed it, I have had it parked and trying to find help with it, but not getting response from anyone that can work on it! Please help!
Thank you
Birdieaimee is offline   Reply With Quote
Old 03-07-2022, 02:23 PM   #2
fo4imtippin's Avatar
Chassis: TC2000 28ft
Where were you driving (up a mountain, on the highway, in the city)?, how long was it operating correctly before this issue?, What transmission do you have? What does the engine temp look like? Is this just after startup?
Old 03-07-2022, 02:39 PM   #3
Engine: Mechanical 5.9
Rated Cap: 35 Feet
Pull the transmission dipstick and see if it is really that hot. I would imagine it would be smoking at those temps. Perhaps it is a gauge issue.
www.MzDazy.net
mhaisten is offline   Reply With Quote
Old 03-07-2022, 09:54 PM   #4
sportyrick's Avatar
Chassis: F33695
I don't think it would run long at 400, check the gauge and sending unit. Hit it with a temp gun to get the correct numbers.
Old 03-07-2022, 10:36 PM   #5
ewo1's Avatar
Thank you
Read page 26 of this Allison operators manual, it will provide insight on your situation.
https://www.wanderlodgeownersgroup.c...t=OM2157EN.pdf
Check the color of the tranny fluid. If it is a dark red almost black, fluid got roasted!
If still a clear red ( not dark/burnt) try going for a short test drive to see how it responds.
You can also pull codes on the tranny, that might provide more useful info.
Never mind….
I don’t know why I thought you have an MD3060 tranny ????
What tranny do you have ????
Old 03-08-2022, 07:17 AM   #6
Never mind….
in 2004 it should be a 3060 or a 2000 series..
do you have any check-engine or check trans lights?
a modern allison transmission if it loses J1939 connectivity to the engine will fail to lock the torque converter as it uses converter "spin" as a means for determining throttle input.. this will overheat the trans in short order...
if its truly hit 400 degrees then id expect the dip stick to be blueish on the end and the fluid to smell burnt...
Old 03-08-2022, 08:36 AM   #7
It's just on a city road. I ran the engine for maybe 20 minutes, and was only driving for about 5 minutes when it happened
Old 03-08-2022, 08:37 AM   #8
Thank you very much. I will try this when I run it today
Old 03-08-2022, 08:39 AM   #9
Thank you. This is useful information and I will look in to the questions you gave me. I really appreciate it
bluebird, cummins, overheat, temperature, transmission
