Old 05-13-2020, 09:34 AM   #1
8.3L cummins
Did they make a front engine, flat nose, 8.3L cummins bus? Or only a 6.7 and 5.9?
I want to chop a few feet off the back end behind the axle and make a 31 ft bus
DrTwitch is offline   Reply With Quote
Old 05-13-2020, 10:46 AM   #2
Bluebird made All American FE's With the 8.3 Cummins.
I am not a huge fan of FE's and the 8.3 would be even more difficult to work on than the smaller engines.
I love my 8.3. I set out specifically looking for an 8.3. But... In an RE. Engine access is stellar and that big, noisy, hot beast is 30+ feet behind me when we are driving.
Old 05-13-2020, 11:09 AM   #3
Yeah but If I chop the back 8 ft off a rear engine bus the bus wont move
Old 05-13-2020, 11:29 AM   #4
Cutting 8' out of the middle would solve that. There pics of a shortened RE on here somewhere. Maybe someone will remember where and post a link.
Old 05-13-2020, 11:56 AM   #5
Frame work and rewelding and drive shafts balancing etc is beyond my ability.
I have 60% confidence in my ability to cut the metal straight enough to reweld the end clip back on. Cutting off excess frame sticking out the back I can do. Removing is doable. Reattaching structural underframe is the nonstarter to this project
So while I feel chopping down behind the axle is doable, anything forward of the axle is not
Has anyone made a 30ft monster out of the better engines? Currently the only midsized flatnoses I find available are cat engines or 545 transmissions
I want the robustness of the Cummins and an Allison 2000 or better on a shorter 30' bus I can maneuver easier than a 40'
Old 05-13-2020, 12:24 PM   #6
Chassis: TC/2000
Engine: 5.9 Cummins 12-valve
Rated Cap: 1
https://www.govdeals.com/index.cfm?f...67&acctid=1097
Probably would have to relocate the fuel tank.
BamaBus is offline   Reply With Quote
Old 05-13-2020, 03:38 PM   #7
No driveshaft work needed on the RE. To significantly shorten an FE or CE may require shortening driveshafts.
Old 05-13-2020, 03:57 PM   #8
Coachwork: Winnebago
Chassis: Ford F53
Engine: Ford Triton V-10
Rated Cap: currently 2
I think OP wants to shorten a FE behind the drive axle but it was suggested a midship cut in an RE. Admittedly I'm less of a fan of a midship slice and splice - it seems less complicated but more risky cutting the middle of the truck frame. There's also no driveshaft but still plenty of other stuff like fuel and air lines, electrical, and transmission controls to contend with in a midship cut.
Sehnsucht is offline   Reply With Quote
