Old 06-04-2021, 10:10 AM   #1
chromaglow's Avatar
Chassis: All American RE Flat Nose
Engine: Cummins 8.3 260 Allison MD3060
Rated Cap: Just 1 right now
Post Adding oil
I am about to do my first oil change.
What is this round port with a twist-off lid on the front right of my engine?
In the picture it's right above the red ISC logo badge
Can I add oil through it?
The only other place I see to add oil is on the top of the block all the way at the back and it looks like I would need a super long neck funnel and a lot of patience.
I have read my manual and watched as many youtube videos as I can for changing oil on an 8.3 and I can't find good information.
Aside from answering the question above does anyone have a good resource about how to learn this information. I am a very do-it-yourself learning type so I want to be able to do all my maintenance.
I still need to find resources to learn to do basic things like start the bus the correct way, maintain and bleed air brakes etc.. when I got my bus they just handed me the keys and said see ya. I can't figure out what I need to know to even google search. If I knew what needed to be done routinely I could then search those things and learn them. I should clarify I have read the maintenance schedule for my engine, but I also mean practically as a bus owner what things I need to always be looking at and monitoring etc...
Thank you all!!!
https://www.skoolie.net/forums/membe...cture26263.jpg
chromaglow is offline   Reply With Quote
Old 06-04-2021, 10:21 AM   #2
s2mikon's Avatar
Engine: Cummins 8.3
Yes that is the oil fill.
s2mikon is offline   Reply With Quote
Old 06-04-2021, 10:22 AM   #3
s2mikon's Avatar
Engine: Cummins 8.3
Pre fill the oil filter. Use 15w40 oil. I use rotella.
Old 06-04-2021, 11:03 AM   #4
chromaglow's Avatar
Thank you!
What brand of oil filters do you recommend?
Old 06-04-2021, 11:05 AM   #5
s2mikon's Avatar
Engine: Cummins 8.3
wix, baldwin, fleetguard are 3 good ones. NAPA and carquest are wix.
Old 06-04-2021, 11:39 AM   #6
strange one for me.. when I use WIX branded filters on my DT360 i have to tighten them ungodly tight to not leak.. when I use NAPA branded filters (which should be wix) I tighten them by hand plus a little and they never leak
Old 06-04-2021, 02:24 PM   #7
s2mikon's Avatar
Engine: Cummins 8.3
Wix is now part of Mann and Hummel. Happened about 4-5 years ago. Maybe NAPA is something else now. The insest that goes on in the automotive world is breath taking.
Old 06-04-2021, 06:37 PM   #8
chromaglow's Avatar
I have seen some people have a tool that is used with a socket set that can lock on the bottom of the oil filter the way you would grab a lightbulb from below. Used to tighten or break it loose. I can't seem to find what it is called to be able to get one. Any help would be great! I assume there must be something similar for the fuel water separator also. I am going to do both since I don't know when it was last done.
Old 06-04-2021, 06:40 PM   #9
s2mikon's Avatar
Engine: Cummins 8.3
I use a strap wrench. It is nylon web with a socket 1/2"
Old 06-04-2021, 06:46 PM   #10
my filters aren't pre-filled. says not to in the manual. Cat 3126... fwiw.
