Old 09-13-2020, 11:55 PM   #1
Engine: 5.9L Cummins 24V
Rated Cap: 36200
Check Engine Light - Error code 51??
Hello all,
Hoping you can help me understand this error code Iím getting.
Check engine light consistently goes on and off. I purchased a ScanGauge D per the recommendations here and read the code. There was only this code present and I cleared it with the tool. Drove the bus a little and the light came back on. Read it again and same code.
Having a hard time finding codes under 100 and also the failure mode is 11 = not identifiable.
And help would be much appreciated.
File Type: jpeg D73E8BFD-FDA7-46B1-8C54-66985007A529.jpeg (87.4 KB, 3 views)
BCriswell is offline   Reply With Quote
Old 09-14-2020, 09:05 AM   #2
Chassis: TC/2000
Engine: 5.9 Cummins 12-valve
Rated Cap: 1
Originally Posted by BCriswell View Post
Hello all,
Very few results for that code. Seems to point to the lift pump. This would only open for me in Firefox.
https://www.justanswer.com/heavy-equ...de-51-aux.html
This is for Thomas but look at page 28. Not a much help. I read somewhere that an additional sensor was added if the Cummins campaign 0504 was completed to monitor the lift pump.
http://www.carolinathomas.com/wp-con...mas-Bus-70.pdf
BamaBus is offline   Reply With Quote
Old 09-18-2020, 10:19 PM   #3
Rated Cap: 36200
Ok, I was going through my pictures and posted the wrong one. That was from when I checked the fuel filter and makes perfect sense why that code got thrown.
The reason the light keeps coming on is actually ID 1, FM 5. The failure mode is current below normal or open circuit, but not sure on ID 1. The Thomas link above shows 1 as a clutch switch? The bus is an automatic.
Sorry for posting the wrong code read and thank you for the help and info.
File Type: jpg 06D631FB-E56D-424B-B11B-0D5CD62F4AB1.jpg (74.1 KB, 1 views)
