Originally Posted by drenn12
Ahhhh sorry, my bad. No, there is no smoke while the bus is cranking. What does this mean in terms of solutions if this is the case and there is no fuel getting to the injectors?
lift Fuel pump
tank pickup clogged
fuel filter clogged
would be my first thoughts.
I'd check the fuel filter and see if it's full first, if not fill it with ATF and try to start it.
If it's full of fuel then your going to have to test fuel pressure and see from there.
DO NOT USE ETHER OR STARTING FLUIDS.
But no smoke on cranking for sure means no fuel is making it into the cylinders.
Maybe before trying to restart get some diesel and make sure there is fuel in the tank....
I bought a F350 no start once, ford dealer charged him more than I paid him for the truck and still couldn't get her going, front tank the pickup screen was so clogged nothing was getting through, rear tank the pickup tube was broken off. Hour after screwing around it fired right up.
