Old 12-02-2019, 09:04 PM   #1
Cummins injector seals
How much would injector seals cost to replace? What do y’all think of price? Thank you for your time.
ddmskeeter1 is offline   Reply With Quote
Old 12-02-2019, 09:16 PM   #2
It requires injector removal if it's the seals that I think they're talking about.
Could be an easy job if you're pretty mechanically inclined and ambitious.
As far as the seals go, you can get a kit for all 6 for 20 bucks or so.
Price isn't bad for a 12v cummins, as long as the bus isn't rusted out.
Old 12-02-2019, 09:41 PM   #3
I’d have to pay someone to do the job. Wondering how much that’d cost?
Old 12-03-2019, 08:24 AM   #4
Should be done for around a few hundred bucks. Only takes a couple hours to remove and install injectors. That's if it's the injector seals, they didn't mention why it needs injector seals.
Old 12-03-2019, 08:54 AM   #5
And if it was an inexpensive/relatively easy repair...
Why isn't it already done making the bus worth more for resale...?
Your spidy senses should tingle...
As with any used car -- if you're not knowledgeable enough to carefully check it out -- pay a mechanic you trust to check it out.
Old 12-03-2019, 12:26 PM   #6
Mine sure are. But I'm a mechanic, so anything that someone says to me about a repair is taken at face value.
It could be a good deal from someone who is done and just wants rid of it.
Or it could be a basket case being sold as a simple fix.
Everybody should always do their due diligence when making a purchase.
To the OP.
If you have no mechanical abilities, I'd look for something that is listed as problem free. Granted, that doesn't necessarily mean it is, but you have no way of checking it unless you have someone go through it for you.
