Old 07-10-2020, 09:02 AM   #1
Chassis: TC RE
Engine: 8.3 Cummins MD3060
Engine noise on start up
This start up video is after sitting for over 2 weeks. One little puff off black smoke on initial start which isn’t a problem. My question is about the change in tone at the 15 second mark. It’s much more noticeable in person. I don’t know how to describe it. It’s not a change in RPM, or a change in pitch, Moore like a change in the harshness of the diesel sound. I haven’t noticed that it ever goes back to the initial tone until the next start up. Also haven’t shut it off and restarted it immediately to know if it only does it on cold start up. Any ideas?
JackE is offline   Reply With Quote
Old 07-10-2020, 09:21 AM   #2
Phantom5824's Avatar
Coachwork: Gillig
Chassis: Phantom 40'
Engine: DDECII 6V92T Allison MT647
Rated Cap: 37,400 lbs of potential
JackE
Is that the sound of the EGR valve being open? It does have a more 'hollow' sound after 0:15, doesn't it?
Just my guess...
Rich
Phantom5824 is offline   Reply With Quote
Old 07-13-2020, 09:39 AM   #3
Chassis: TC RE
I don't know enough about these to know if it even has an EGR system. I looked the engine over and didn't see anything that resembles an EGR valve that I'm familiar with.
Anybody else have any ideas?
Old 07-13-2020, 10:08 AM   #4
No egr on a 99.
Old 07-13-2020, 10:15 AM   #5
Chassis: International 1753
Engine: 6.9 International
Sounds like a load of some sort is being applied to the engine. Like the alternator being turned on or some other load. You can remove the valve cover and do a valve lash inspection/adjustment.
Old 07-13-2020, 11:28 AM   #6
vanaguy's Avatar
Engine: Cummins 8.3 ISC
I don't have any ideas, but I wanted to chime in with a "me too."
Mine is also a '99, and it does this noise change on every cold start. I haven't noticed whether it does it on warm starts, but I will look for it now.
It doesn't seem to have any effect on how well my engine runs.
I had also been guessing that it was some accessory kicking in, like maybe the air pump.
vanaguy is offline   Reply With Quote
