a)
Your word 'canister' does not compute on my end.
Are you referring to the housing or the replaceable air-filter insert?
b)
As long as a replacement air-filter has adequate flow, any filter housing should be as effective and efficient as the original.
I wonder about visiting a heavy-truck dismantlers.
I bet they might have a filter housing for a semi-truck with an engine double the size of your Cummins 8.3.
Fabricate a bracket and plumbing, and you should have more than enough flow.
With adequate flow, the housing has zero reason to collapse.
Who spent $400 on the housing in your photographs?
Why was it replaced?
We have a 1996 Cummins 8.3.
Our engine is a 12-valve mechanical.
In my wildest dreams, I cannot imagine any reason for my air-filter housing to collapse.
