the "intercooler blades" are actually called electric shutters.. they are designed for busses being used in cold weather to help them stay warm.. those shutters open usually at 185-190 or so.. depending on where the sensor is.. there should be 2 sensors, one for the airt shutters and one for the fan. the one for the shutters is a normally closed.. meaning when its cold the switch closes and engages the shutters, they are notorious for operating in hot weather... my DEV bus has those shutters.. and I installed an air temp sensor that if its above 50 degrees outside rthose things never operate.. you dont need them except in really cold weather.
the temp for the fan is usually in that 205-210 degree range to turn on.. the sensor can be anywhere.. a switch isa fine except until you forget to turn it on.. its not good on the engine to widely swing its temperatures... or wait till the alarm goes off to tell you to turn it on... run the fan all the time and its just very noisy and wastes fuel...
its typically a temperature switch as i believe your engine is Fully mechanical with no computer? if so just find an adjustable switch with the same threads as the one in the bus and you'll be set... also a good idea to make sure the fan circuit has power.. (I dont know how youre mechanic ran the switch.. if it was a powered circuit or he used existing power at the clutch and just grounded the second wire...
typically a fan clutch circuit will have a hot lead all the time on an ignition circuit and then the switch grounds through the clutch causing engagement.. not sure how yours is.
You are correct about the setup - all mechanical and an electromagnetic switch. I can see the two sensors and it appears clear which is for my dash gauge and which activates the clutch.
I stole an unused Warning Light switch on my control panel and ran a ground to the non-hot side of the clutch harness. So I pull the switch to throw a ground, which activates the clutch. When I get a replacement temp sensor it will also activate the clutch as designed.
