Originally Posted by fo4imtippin
Does the check engine stay lit?
If so, you can buy a scanguage d, blue fire or nexiq to read the code.
If it flicks on intermittently, change your fuel filters and see if it goes away.. they have a fuel pressure sensor that will light up or water in fuel.
Appreciate the reply! When I turn the vehicle on, the light is off. But it either turns on shortly after starting up or when I rev the engine up. I called freightliner cs number and they said I can’t retrieve codes from dash so I have no idea what the engine check button is for. I ordered the scan gauge d today, but there was a shop nearby that scanned it for me and there were two active codes but he didn’t know what it meant. I changed the fuel filters but it didn’t help. Here are the codes that they pulled.
Auxiliary equipment sensor n. 3 input signal (oem switch)
Engine synchronization error, fuel pump control module:data erratic, intermittent or incorrect.
