http://www.irv2.com/forums/attachmen...26d=1311472846
download this, it's a partial of an isc troubleshooting manual, and then go to page 53/277
Basically, this code is saying the front pumping element of your injection pump isn't operating correctly.
If you have only 275, and not 328, you're issue isn't likely with the lift pump or fuel filters, both of which should be on the side of the engine. Often times, there is a water seperator towards the rear of the bus that is forgotten about and neglected as well.
You can try and change both filters, add your choice of fuel additive, and see if it improves, but you'll likely be needing a mechanic to do any real diagnostics.
