Old 08-10-2022, 08:24 AM   #1
Chassis: MVP ER
ISL engine
I have seen a couple of school busses with an isl motor. Do thes have Jake brakes and what is the typical power rating for these motors? This may be an interesting conversion into my bus in the future. Also is the emmision stuff easily removable from the newer isl or is preemmisions motors easyto find in busses?
ism minerals is offline   Reply With Quote
Old 08-10-2022, 08:41 AM   #2
fo4imtippin's Avatar
Chassis: TC2000 28ft
Looks like detuned they might be around 350 and can be flashed up to 450.
It's a big motor. I have seen them in transit buses and RV's.
ISL had no emissions until 2007. Would recommend to stay before that. If you go to a newer model, you'll spend thousands to have it all deleted and most shops won't help you if you need it..
Looks like you can add a jake brake to the motor of wanted.
fo4imtippin is online now   Reply With Quote
Old 08-10-2022, 08:58 AM   #3
Chassis: MVP ER
Thank you, would be nice, wondering how common there were in school busses before 07
Old 08-10-2022, 09:12 AM   #4
What school buses do you see these in? I have only seen them in the coach buses, and transits. Are you swapping something into a rear engine or conventional?
Old 08-10-2022, 12:17 PM   #5
Chassis: International 1753
Engine: 6.9 International
ISL took the place of the ISC when cummins engines were consolidated. Never saw a diesel ISL in a school bus. It's a possibility that they used them on the RE type D transit buses like an ISC could have been had.
Much more common that I've seen are ISL-G, which run off natural gas. It's cool if you're into that type of thing, but I don't think I'd buy one. Too many hassles with tank certs and refilling to be worth it for an individual IMO.
Old 08-10-2022, 12:21 PM   #6
ISL could have a jacobs engine brake installed. Never seen one with one in a school bus. Power levels can be found on the internet doing a google search. With the epa cracking down on guys installing deletes, I wouldn't say that any engine emissions component is easily removable any more.
A link to the buses in question would be worth 1000 words.
Old 08-10-2022, 02:14 PM   #7
Chassis: MVP ER
https://m.publicsurplus.com/sms/auction/view?auc=3098017
I did a gates vin decoder its says isb In the bus. Most likely a typo from auction site as they stated isl. Was hoping this was the case and if so hoping there were pre emissions ones also especially for a thomas skoolie. As I would do the swap Into my bus in the future.. 400hp 1200ft/lbs and a Jake, what not to like about that
Old 08-11-2022, 09:04 AM   #8
Call your nearest thomas dealer with the vin, and they should be able to tell you.
