Old 01-08-2023, 01:29 PM   #1
Chassis: Thomas Built MVP-ER
Engine: 5.9 Cummis Tan Block
MD3060 stuck in neutral
2001 Thomas built Cummings 5.9 with a MD3060 that is not shifting into gear. Staying in neutral. These are the codes that showed up on display.
#1. 45 - 22 G SOLENOID CIRCUIT OPEN
#2. 45 - 14 C SOLENOID CIRCUIT OPEN
#3. 22 - 14 ENGINE SPEED SENSOR
There's enough fluid and I also changed the shifter housing
No luck. Currently checking the harness for any corrosion and broken wires
Prince408 is offline   Reply With Quote
Old 01-27-2023, 02:10 PM   #2
Coachwork: Our hot little grubbies...
Rated Cap: Three RedHeelers
Our rig -- 1996 Ford CF8000
Our trans -- Allison 3060.
After replacing our starting bank, we had a similar no-shift.
We discovered a 'Hot' lead from a positive terminal to the trans brains.
After testing the length of it, we realized the circuit-breaker failed (near the positive terminal on the bank).
We replaced the circuit-breaker, and this cured our no-shift.
LargeMargeInBaja is offline   Reply With Quote
