08-26-2018, 12:27 AM
Chassis: CS RE
Engine: ISC 8.3 L 260 hp
Opinions on ISC gearing.
I'm planning a gearing swap from my current 7.17 gearing ratio. (It is painfully slow) My bus is a 36 ft RE bluebird high ceiling. Current weight with all the seats is around 23k. I'm not sure what my final weight will be after conversion but I want to go as light as I can.
The drive train is an ISC 260 with an allison B300. The tires are 11r22.5 (loaded radius of 19.3 inches).
From what I have read ISCs like to cruise around 1800 rpm on flats and I would like to cruise about 65 mph. I will be driving both rolling interstate and mountain roads.
Using the gearing calculator on spicers website I narrowed it down to three gear ratios depending on wether or not I can get 6th gear unlocked.
4.78 if I get 6th (.65 overdrive): 66 mph @ 1800 rpm
4.44 for 5th (.75 overdrive): 62 mph @ 1800 rpm
4.10 for 5th 67 mph @ 1800 (might be too high)
Any opinions on these ratios or my assumption of 1800 rpm cruising?
Also does anyone have similar bus size, drive train, and axle ratio thats been converted and how does it work for you?
Thanks
Ted
08-26-2018, 12:47 AM
Engine: TE 444
Rated Cap: 12
Go for the 4.10, no one has been able to get bluebird to send them a letter to unlock 6tn gear
08-26-2018, 08:07 AM
Chassis: CS RE
Thanks Kubla,
I am thinking 6th gear isn't going to happen but I'm going to have my local shop look i to it. I may want an updated shift program from allison with the new rear end.
Ted
08-26-2018, 09:47 AM
I have a very similar drivetrane in my Bluebird except 5.38 gears.
I would sure like to have a little bit longer legs on the highway. It is geared just right in town.
I would be reluctant to go as tall as 4.10 for fear of losing in town driveability.
I did find an outfit in Florida that claim to be able to reprogram our TCM's without a letter from Bluebird.
08-26-2018, 04:53 PM
Chassis: CS RE
Thanks Steve,
I am a little worried the 4.10 could hurt mountain road performance. I'm also not sure the ISC would have enough power to hold the trans in 5th when cruising on the flats. Thats where it would be nice to be set up with the 6th gear. Better to downshift .65 to .75 than .75 to 1.
If my shop can't come up with anything I'll have to get the info for the shop you found.
Ted
08-26-2018, 07:02 PM
wow!! a 7 something rear? that's the highest number i've heard in a differential.
i don't know why, but i have never seen a pusher with a ring gear in the 4's. that said, a 260 ISC should not have any problem pushing that.
ol trunt has mentioned horsepower/grade/ gearing charts, but i've never found anything to the sort.
i have a FE 190hp 5.9. - 4.78 rear and make about 67 @25oo rpm on the flats. a 4.10 swap would be nice.
08-26-2018, 07:17 PM
And I thought mine was insane at 5.38 and only good to 45 mph!
08-26-2018, 10:22 PM
Chassis: CS RE
They also made a 8.17 for that axle. That would be snail pace... but a snail that could pull anything.
Ted
08-26-2018, 10:31 PM
Chassis: CS RE
I'm going to check with my local shop and see if thier version of Powerspec has the ISC. It has a gearing calculator that lets you put all the variables in like engine tuning, GVW, frontal area, transmission gearing, and intended use economy vs power. The free version I downloaded had newer and larger engines but no isc.
Ted
08-26-2018, 10:35 PM
Originally Posted by TJones
Thanks Steve,
Ted
When thinking of gear changes, think of how long you'll spend going over mountains compared to how much time you are actually travelling down the road saving fuel with the higher geared bus. There was 2mpg difference in 10 mph between 80-70. I went across the country and am sure glad my ratio was not lower. 43 hours driving, maybe 2 of it was in mountains, Just sayin
08-26-2018, 11:48 PM
Chassis: CS RE
Thanks Marc,
That is a good point and I would still have another 4 gears to use for mountain driving.
Ted
08-27-2018, 12:31 AM
Thanks Marc,
Ted
My trip was from Seattle to Atl., so I went through pretty much every big mountain range.
08-27-2018, 08:48 AM
I recommend taking mountains slow anyway.. i realize modern society seems to be all about driving across the countrey in record time.. but I would build a bus to cruise mild hills.. so it doesnt slow down on the normal hills one encounters.. heading up overpasses, the 2-3% grades common in many areas of the country.. when you encounter those 5-6% and higher grades then downshift , slow down and let the bus run without your foot to the floor..
UNLESS thats where you plan to do mist all your travelling.. if your main area oif travelk is going up in the mountains to camp or live then id want to gear my bus to pull mountains hard and not get as great of mileage in the flat lands..
while diesel engines can and do run close to their redline without issues, they generally dont like to.. I like to highway cruise my engine about mid range between peak torque and peak HP... my 444E gets peak torque at 1400 and peak HP at 2300.. its most happy in that 1700-1800 range.. its redline is 2600.. im over-geared onb my red bus.. when I turn on 6th gear it drops to about 1550 or so on the highway cruise.. its efficient but only good on flat ground and has zero power for asnything but until it kicks down to 5th..
08-27-2018, 09:27 AM
Chassis: International 1753
Engine: 6.9 International
Go for the 4.10, you should have enough torque for it
However, like turf mentioned, I've never seen low ratios like that in a pusher axle. So you might be looking for hens teeth/paying big bucks for it. Then again, most of the busses I work on are FE's, so there is that.
I've never played with cummins powerspec. Never had the need. I'll look and see if it's on the laptop and if we have ISC as an option.
08-27-2018, 11:47 AM
I'd be all over something like a 4.10 for my TC2000. I'm under no illusion as to how fast I can get up a hill!
08-27-2018, 11:54 AM
I have driven my 8.3/MD3060 equipped A3RE in town quite a bit and a couple of trips over the mountains.
I have 5.38 gears and would love to have 6th gear unlocked. I would, however, be reluctant to go a whole lot taller on the rear gears for fear of losing around town drivability.
08-28-2018, 12:33 AM
Chassis: CS RE
Thanks for the input everyone. I found a little info from cummins for gearing for vocational trucks that saw occasional high speed use. They recommended gearing for 2000 to 2150 rpm @ 65 mph for the best balance of performance and fuel economy. This may be why many buses are spec with the 5.38 with the allison 3000 series.
Ted
08-28-2018, 10:08 AM
Lots of good info here. But, just what axle is in it? Meritor? It's a Q-bus? What year? Anyone know? I know my motorhome has a Dana S135. Knowing that, I've found I could switch to a few ratios with just a ring and pinion swap, others need a whole new carrier. I'm sure similar information could be found for whatever axle this is.
08-28-2018, 10:47 AM
Just remember that making gains on the top end means sacrifices on the other end. The more you go higher in gear you lose performance on the bottom end. Take offs will be more sluggish.
08-28-2018, 11:18 AM
do it!!!
do a ring swap for us all to see!
i think that's the least changed item on all our wish lists and i'd like to see more of them. it makes the most sense to squeeze the speed that we desire out of them.
