Old 08-27-2022, 08:18 PM   #1
Overheating / Serpentine
Hi,
I have a 1998 Bluebird with a Cummins 6bt engine. The bus was overheating so I topped off the coolant and oil, it was still overheating. I looked closer and found the shredded belt (serpentine belt). I have the belt ordered for delivery, but have no idea how to put it on. Any advice, videos or diagrams of how to put it on would be greatly appreciated.
Thanks, Hope
Hope is offline   Reply With Quote
Old 08-27-2022, 09:42 PM   #2
Year: 1954
Coachwork: wayne
Engine: cummins 12 valve
What kind of bus?
Pictures of the engine. We don’t have enough information to help you
William
Old 09-08-2022, 10:37 PM   #3
Check to make sure the flaps
Check to make sure the flaps on the radiator are open when the bus is running. My bus has flaps that are supposed to open and close automatically. Had to disconnect the wire for the flaps why the bus is off. Haven't had a heat issue since
steveng72490 is offline   Reply With Quote
Old 09-09-2022, 02:38 PM   #4
Rwnielsen's Avatar
Chassis: TC2000, 40' MPV
Rated Cap: U/K
Originally Posted by Hope View Post
Hi,
Thanks, Hope
I have a 98 with a 5.9 too. I believe, unfortunately, that you need to pull the radiator. I'd love to be wrong. Mine's in ok shape but it's old.
Rwnielsen is offline   Reply With Quote
overheating, serpentine
